matlab script outputting different data
Hello
Fell into the problem of getting different output on graph from matlab script node.
I apply welch function in matlab over a data and ouput 2D array onto waveform chart.
however the output plooted by matlab plot command has different amplitudes than the labview graph.
(3,074 Views)
I think you got to clear things up alpine_t.
Attach your labVIEW vi, take a screenshot from your matlab pogram,...
Regards
Ruts
(3,065 Views)
There are millions of ways things can be different, so you need to be a little more specific. Is it just a scaling issue? How different are they? What are the offset and multiplier settings for the y-axis of the graph?
You use the terms "chart" and "graph" interchangeably but in LabVIEW they mean very different things. So what is it?
(3,056 Views)
