matlab to labview(urgent please)
data=load('D:\d.txt');
for n=1:240;
    t=1024*n; i=t-1024+1;
    a=data(i:t,1);
    elev=-data(i:t,2);
    p=data(i:t,3);
    r=-data(i:t,4);
please ane one help how to code in labview for above matlab procedue.. urgent please
thanks & regards
srinath
Message 1 of 14
(4,147 Views)
Message 2 of 14
(4,141 Views)
 please upload the  txt file also..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 3 of 14
(4,138 Views)
respected sir
here i am sending text file also.. here the first column shows the data of the ''a''
                                                the second  column shows the data of the ''elev''
                                                the thied column shows the data of the ''p''
                                                 the first column shows the data of the ''r''
for n =1:240; shows that loop count is 1 to 240
                                                              t=1024*n; i=t-1024+1; shows the conditions
        a=data(i:t,1); shows during hte first loop it has to read first column 1024 values and during the 2nd loop count t has to read first column 1025 to next 2048 values and cont.. up to 140 times
        elev=-data(i:t,2); shows during first  loop it has to read 2nd column 1024 values and during the 2nd loop count 2ndhas to read 2nd column 1025 to next 2048 values and cont.. up to 140 times
        p=data(i:t,3); shows during first  loop it has to read 3rd column 1024 values and during the 2nd loop count 2ndhas to read 3rd column 1025 to next 2048 values and cont.. up to 140 times
        r=-data(i:t,4);shows during first  loop it has to read4th column 1024 values and during the 2nd loop count 2ndhas to read 4th column 1025 to next 2048 values and cont.. up to 140 times
        end
 i think ex:
thanks and regards
 srinath
Message 4 of 14
(4,096 Views)
hai up to 240 times it has to count .. not 140 .. i did a mistake in above post sorry...
please can u try as per above post requirements.....  its urgent..
thank & regards
srinath
Message 5 of 14
(4,088 Views)
Please try to keep the discussion in one place so all of the necessary information is in one place. Let's move all of the discussion in the other thread that Mike pointed out.
Message 6 of 14
(4,085 Views)
Accepted by topic author adapa
please look at the attached VI.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 14
(4,073 Views)
respected sir
    i think u have done in labview 8.5. but i have 8.0.version.  my friend having the latest version . i will try in that version and i will give the reply by soon..
that coding is  is very important to me .. if it is successes  i am very thankful to u.
thanks for ur valuable  advices.. i wiil be keep in touch with u..
thanks & regards
srinath
Message 8 of 14
(4,063 Views)
respected sir
 your program is working absolutely as per my requirement. i am very thankful to you sir.
i am very new to labview coding. i am doing my pg project by using labview. initially i did my project in matlab. but suddenly my guide asked me to change software to labview. so i got problems . can u help me in this coding if i get the doubts in project. can i know ur mail id please.
thanks & regards
adapa srinath
mail:adapasrinath@yahoo.com
Message 9 of 14
(4,046 Views)
respected sir
thanks & regards
adapa srinath
Message 10 of 14
(4,040 Views)
