matlabscript node copy just first value of an array
HI everyone
I'm having some trouble whit the matlabscript node.
Right now the worst one is that I have several output that are array and defined so, that are arrays in matlab (in the variable editor show so) but when I pass them out of matlabscript labview transfer only the first value ( that means if I place a probe just outside the matlab script output I see a single value a non an array and that value is the first):( anybody know why?
Another point I need to make the interaction between matlab and labview the fastest possible, what can I do?
Thank
P.s. I can't post the matlab code but I add the vi 🙂
(2,711 Views)
Possibility, Matlab returns a column vector and you specify a row vector in LabVIEW. Then, only the first element is returned.
(2,688 Views)
