matrix inverse bug
We are working with labview8 and the matrix inverse (at least the 4 by 4) differs from the result of matlab, is there something that I could be doing wrong?
Message 1 of 8
(4,526 Views)
Do you have a matrix for which you get the wrong answer? I tried it with a few matrices and I was getting the same answer.
Message 2 of 8
(4,516 Views)
You are using the "Inverse Matrix" primitive from the linear algebra palette, not the 1/x primitive of the numeric palette, right?
Message 3 of 8
(4,511 Views)
here... thanks for the quick response!
Message 4 of 8
(4,481 Views)
Hi macrom,
atleast the MathScript node gives the same result as the attachment shows...
Edited: changed the mathscript command from "a^-1" to "inv(a)" - both give the same result (within DBL precision).
Message Edited by GerdW on 07-03-2008 01:25 PM
Message 5 of 8
(4,475 Views)
Hi GerdW,
Thanks for the reply.
Im sorry I cant open the vi file, I only have the labview 8 and the file is saved as 8.5
I've tried the inverseMatrix.vi and the mathscript with both a^-1 and inv(a), all three are consistent with each other but still inconsistent with Matlab and Mathematica. A mathematician friend of mine said that it could be a numerical inestability of the algorithm. Has anyone heard of Labview having this problem? It could still be that its Matlab or Mathematica.
Anyway, I decided to use a matrix that works well in all the cases.
Thank you very much!!!
Message 6 of 8
(4,458 Views)
Well, Mathscript is basically LabVIEW under the hood, so I don't expect them to be different.
How different are the results between LabVIEW and matlab?
I did some test and the LabVIEW version seems OK.
  1. If you take the inverse twice, you get the input matrix back within 1e-17.
  2. I also tried the scilab script node, the results differ from LabVIEW by about 1e-16, or about the precision of DBL. So clearly they use an entirely different algorithm, but give the same result!
Message Edited by altenbach on 07-03-2008 08:13 AM
Message 7 of 8
(4,443 Views)
Hello macrom,
If it is just a small difference, it is most likely due to algorithmic differences.  Can you post the result matrix you get from your computation in the MATLAB® software?
MATLAB® is a registered trademark of The MathWorks, Inc.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
Message 8 of 8
(4,392 Views)
