maximum controls/indicators on Front Panel ?
What is the maximum number of controls/indicators that can be used on the Front Panel (including hidden ones) ?
Rob
(3,415 Views)
To my knowledge, there is no limit until you run out of memory.
Greg McKaskle
(3,415 Views)
LabVIEW 6.1 can not handle more than 555 top level controls (controls or
indicators with terminals) in any single VI. If you have more than this,
the VI builds a corrupt description of the dataspace and once saved, the
VI cannot be loaded successfully. It may not always fail in the same way,
but it will fail. A workaround is to place controls into clusters. These
clusters only count as a single control/indicator.
Marcus Monroe
(3,415 Views)
After saving a vi with > 555 objects, it cannot be loaded anymore. Is there any way to repair the vi or delete the last added object?
(3,415 Views)
