maximum in part of graph
how can I get the maximum values of the actual shown part of a waveform graph? I choose a part of the graph with the graph palette and want to have the maximum values online.
thanks for any help
yves
(2,494 Views)
Hi Yves
The data in the graph is an array, so use property nodes to get your x displayed min and max points and use them to extract the subarray of displayed data. Then, array max and min should do its work.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,491 Views)
Thanks for your help. I couldn't found the property node to get the array of the displayed data. I thought there should be a more straightforward way.
But extracting the x scale min and max values to get the subarray is okay too.
yves
(2,488 Views)
