maximum x label
The default for the maximum value to be shown in the x scale for a Labview chart appears to be 1023.  How can this be increased?  For example I want data from 0-2000 to be displayed without having to use the scrollbar.
(2,495 Views)
Now I understand your other problem. 0 to 1023 happens to be 1024 points which is the default chart history length. If you want more points on the chart, increase the history buffer by right clicking on the chart.
(2,493 Views)
