mbf file
I have a program that generates mbf files containing data and graphs that I would like to read from labview. Is there a automated converter for this kind of files that can run in the moment that this file is created?
Zied
Message 1 of 14
(5,351 Views)
Hi ziedhosni
Are you sure you mean a mbf and not a mdf file? According to the description that you give it sounds more like a mdf to me.
If that is the case, there is already a thread on this topic on the next link:
https://forums.ni.com/t5/LabVIEW/How-to-read-MDF-file-from-labview/td-p/653353
Wen R
Message 2 of 14
(5,316 Views)
Thanks for your initiaivebut I mean the mbf with b not d.
It is like a file to save data and spectra from mass spectrosopy machine that works under linux.
Zied
Message 3 of 14
(5,299 Views)
Please provide the specifications on the file. You need this information in order to read. What is the make and model of the instrument?
Message 4 of 14
(5,292 Views)
Here is the zipped file, actually it i creature by the software of the mass spectometer running under linux.
Zied
Message 5 of 14
(5,281 Views)
The file by itself is worthless. As I said, you must provide the format.
I really don't care if the file was created under Linux. That is irrelevant. I asked for the make and model. The manual would be nice.
Unlessl you provide the necessary information, you'll have to figure out how to to a read yourself.
Message 6 of 14
(5,275 Views)
I did not understand what you mean. I get the file from the software anf here is the manual for the machine, is this the format you are looking for?
Message 7 of 14
(5,234 Views)
There is no attachment.
Have you read the manual yourself? Do you see a detailed explanation of the file format? The file itself is binary so an explanation of how the bytes should be interpreted is necessary.
Message 8 of 14
(5,228 Views)
I am  really a new to binary files, I am actually a chemist and this was what I got from the company. Just the manual but I did not find any indication about the mbf files.
Message 9 of 14
(5,223 Views)
You still have not attached the manual. You haven't even provided the make and model of the instrument, like I have requested. Why is that secret information?
To give you an idea of complex binary formatting, create an Excel file and then open it with Notepad. Does it make sense?
Message 10 of 14
(5,215 Views)
