meas all 8 channels simultan
I'm a newbi on Labview programming. I have a goal to meas with a USB6009 DIO card all 8 voltage input simultan, and do also record these data. Like a small "scope".
Have anybody a solution for me. I check a sample, but I do not understand these technic.
So please help me.
Best regard from good old Germany.
Michael
Here is my solution for one channel.
(2,628 Views)
That should work just fine for multiple channels. You just need to specify them in the Physical Channel control. Click on the little arrow on the right side and select Browse. Use Shift-click or Ctrl-click when selecting channels. When done, your physical channel control should be Dev1/ai0:7.
(2,626 Views)
