measure analog frequency with PCI or USB
I would like to continuously measure the frequency of a 0-5V square wave from zero to about 4 kHz.  I don't need to record the waveform, only obtain frequency.  The hardware at my disposal include:
1) PCI-MIO-16E
2) DAQCard 6062E
3) USB-6218
Can any of these devices do this?  This seems like a very common task, why can't i find the perfect example to do this.  I'm not having luck with the DAQ assistant. Can someone point me to a simple example?
(2,993 Views)
Accepted by topic author andyh
You may also want to read the following link:
Making Accurate Frequency Measurements
And look at the examples within the zip file here
http://sine.ni.com/devzone/cda/epd/p/id/5000
(2,983 Views)
Thanks for the help.  I'm not sure why that was so difficult to find.  The Labview built in examples seemed to steer me the wrong way.
(2,973 Views)
Glad to help.
You can also do searches within this forum.  There's quite a few examples available.
(2,963 Views)
