measure displacements with lasers riftek triangulation
Hi everyone,
I am new on labview and I want to read the displacements of a laser triangulation by using Riftek lasers.... I am using the NI cDaq -9172 and the module Ni 9203... I have already research the subject but I don't find many information about it... anyone knows how to do it ?
thank you,
Ana
(3,421 Views)
Your question is a bit generic. Could you be more specific? (signals you have to acquire, how is the measurement system. ...)
(3,403 Views)
A quick google and it appears that many Riftek devices offer digital comms, either RS232, RS485 or ethernet. Why not use one of these and avoid the need for an ADC altogether?
(3,379 Views)
I will do impact tests, so the lasers will measure the displacements that the impact tests will do on a beam... I already connected a laser to the daq with the Ni 9203 and the scaled the current input to mm based on the specification data of the riftek laser...
My problem now is that the signal has a lot of noise, specially with the incresing of the sample rate... do you have any sugestions to solve this ?
(3,323 Views)
