measure events per second and store in a spreadsheet
hi I'm an spanish student and I need to measure RPM from a motor and store it. The frequency of de pulses is 30 to 300 Hz. And I need to measure 2 sources at the same time. Some body knows how?
I had been trying whit the FOUT signal for the gate but the time base seems to high and the read is 0.
I need to knoW if is some other way for do it. thank you
(2,440 Views)
The way of measuring motor speed is to use an encoder to convert rotatory movement into a pulse train. The frequency of the pulse train will allow us to know the motor speed once the number of pulses/revolution of the encoder is known.
The best way to measure the pulse train frequency is to use a counter. You can use a multifunction data acquisition board (NI 60xx->2 counters per board) or an specific counter board (NI 66XX->4/8 counters per board).
The basic idea is to continuously count the number of rising or falling edges of a know frequency timebase for a single pulse of the signal comming from the encoder.
Have a look at the following URL.
http://zone.ni.com/devzone/conceptd.nsf/webmain/CD2C8AAED8FA59A486256C230078FE75?opendocument
It has some info th
at could help you.
If you search on NI support web page (http://www.ni.com/support/) with keywords such as "measure frequency train" you will find several examples and documents that will be useful to you as well.
Hope it helps.
César Verdejo
Training and Certification | National Instruments
(2,440 Views)
