measure the complex impedance
I am looking to measure the complex impedance of silicon sample by appying frequency from 20Hz to 20KHz.But need to implement the impedance analyser in Labview...new to this...any help...thx
(3,511 Views)
Which impedance anaylzer are you using?
(3,501 Views)
Need to implement the analyzer in Labview...
(3,469 Views)
What hardware are you using?
(3,461 Views)
National Instruments Educational Laboratory Virtual Instrumentation Suite (NI-ELVIS) contains an Impedance Analyser that was written completely in LabVIEW. After looking at the LabVIEW code that drives this I wouldn't advise trying to write this code as a LabVIEW beginner.
If you have the mathematical equation you wish to apply to a signal being read into LabVIEW (can be easily achieved with the DAQ Assistant) then it is something that myself and the forum community can help you with. Otherwise you may want to rethink using LabVIEW on its own to complete this project.
If you want more information about NI-ELVIS click here.
Hope this helps!
Tom | NIUK
(3,433 Views)
I got the signal using DAQ by applying the frequency to the sample and I had a confusion how to calculate the apmlitude and phase of the signal in Labview.Can I use wein bride oscillator in labview...thx
(3,387 Views)
