measure the speed of the fan in vibration simulator box
i am trying to measure  the speed through analog in channel of sbRIO
i am getting few pulse waveform switching to 5v to 0v and vice versa  with variable duty cycle..
  how can i calculate the speed of the fan
provided values on on the simulator box are
tach out     2 pulses/revolution
maximum speed is 6000RPM
please help me out with this ....
(3,313 Views)
Hi irfan,
when your tacho provides 2 "pulses per rotation" you need to measure the "pulses per second" to calculate "rotations per second".
Sounds like simple math to me…
(3,304 Views)
ya even i could figure out the same
number of pulses measure divided by "2" will give me speed but
i am unable to measure the pulses itself
i am not clear on how to proceed with that
(3,294 Views)
Accepted by topic author irfan789
Did you take a look at LabVIEW examples ? If you have installed NI-DAQmx, you will find many examples showing how to do event counting or frequency measurements.
(3,290 Views)
