measurement and automation crashes (niVISAe plug-in exception)
Hi. Every time I open Measurement and Automation, an error occurs. Attached is the screen shot of the error. I'm using LabVIEW 2011, MAX version 5, and Windows 7. How can I solve this problem? Thank you.
(2,234 Views)
Hello Margarette,
Can you attach the logs described in the error. Also was MAX working well before? Did you make any changes to the computer that might have triggered the errors?
Miriam
Field Applications Engineer
NI Colombia
CLD
(2,218 Views)
