measurement and calibration A2l File Load Error
hello
I would like to ask for help as an error occurred while running the A2l file related program.
When running A2l viewer, the following error occurs.
What is the cause of this error?
The same error occurs when running MC Database Open.vi.
(557 Views)
Your question is best posted on the Automotive and Embedded Networks board
To debug:
1. Open C:\Users\Public\Documents\National Instruments\ECU Measurement and Calibration Toolkit\A2LReaderConfig.cfg
2. Set ENABLE to 1 then save the CFG file.
3. Read the A2L file again.
4. The logfile is created where your A2L file is located
https://tmesystems.net/
(516 Views)
