measurement file format
The output of Write To Measurement File.vi is saved as a .txt file, like this:
My question is I want to make it i 6 columns (each test variable in one column), how to make this?
(2,790 Views)
With that VI, the format is what it is. If you want a table try using the write to spreadsheet file function -- also on the file IO palette.
Despite the name, it creates a tab-delimited text file.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,778 Views)
And whatever function you use, you need to pass all 6 channels at the same time.
(2,769 Views)
