03-01-2010 01:03 AM
hi, all
I use a Keithley 2636A to do measurement only, that is direct measure voltage or current. Input connected to channel A
My question:
when I changed measurement from voltage to current, or versa vice, in first few readings, are just same as that of previous measurement (for examples, If I switched measurement from voltage to current, in the first few readings, I still got the voltage data, and later on, I could get the correct current readings.). Because I did not use buffer to store data, why the data still buffered? I use print(smua.measure.i()) or print(smua.measure.v()) to read the current or voltage directly.
In the each measurement beginning and end, I had issued a command smua.reset() to reset the instrument, respectively.
Anyone any suggestion would be appreciate.
-yuxj
03-01-2010 07:27 PM
If you use C to program your Keithley, you probably contact Keithley, http://www.keithley.com/support, directly, but if you use LabVIEW, could you please attach your code, and 2636a command set so that we can further assist you to analyze the problem?
03-02-2010 03:13 AM
Thanks! I use labview.
command sent to 2636 for voltage measurement
;initialize the 2636 in the measurement beginning
localnode.prompts=0
reset()
smua.measure.nplc = 1
smua.source.func = smua.OUTPUT_DCAMPS
smua.source.leveli = 0.00000E-9
smua.source.limitv = 20
smua.measure.rangev = 20
display.smua.measure.func = display.MEASURE_DCVOLTS
display.screen =display.smua
format.data = format.ASCII
smua.source.output = smua.OUTPUT_ON
;measure loop cycle, to read the data in some tie delay
;when the measurement finished
smua.source.output = smua.OUTPUT_OFF
smua.reset()
command sent to 2636 for current measurement
localnode.prompts=0
reset()
smua.source.func = smua.OUTPUT_DCVOLTS
smua.source.levelv = 000.000E-3
smua.source.limiti = 2E-3
smua.measure.autorangei = smua.AUTORANGE_ON
display.smua.measure.func = display.MEASURE_DCAMPS
smua.reset()
03-02-2010 03:40 AM
This is C code.
Not LabVIEW.
03-02-2010 03:47 AM
These are ascii command sent to 2635 in labview program, but how to post labview program code? it is some graphic block.
The labview prorgram runs normal, but the a few data readings are not correct in a new measurement.
03-02-2010 03:49 AM
