measurement with NI 9211
I want to use a PT 100 or 1000 with my existing NI 9211.
But for using this setting I need an external power supply.
I know normally you supply a PT 100 with 1mA and 1mW.
CAn someone help me with the electric circuit.
thanks
patrick
(2,285 Views)
Hello pwotawa,
unfortunately I have to tell you that this module cannot be used with a PT100. It is meant to be used with thermocouples.
See this post as reference:
https://forums.ni.com/t5/LabVIEW/measure-temperature-pt100-with-cRIO9211/td-p/1919201
You can also find this information in the modules manual.
For use with PTD, you will need something like this: NI9217
https://www.ni.com/en-us/shop/model/ni-9217.html
If you have got one of these, please find the manual here, which tells you how to connect a RTD in the last section:
https://www.ni.com/docs/en-US/bundle/ni-9217-getting-started/page/overview.html
I hope I could help you.
Have a nice weekend,
Best regards!
Christopher W.
Intern Application Engineering | NI Certified LabVIEW Associate Developer (CLAD) | NI Germany
(2,260 Views)
