measuring distance between two points in an image
Sir,
I am working on an eye gaze tracking project. for this, i need to measure the distance between the center of the eyes to inner corner and center of the eyes to the outer corner and display the values. I have to repeat this for all the frames of the video recorded using the webcam. Kindly help me out with this issue asap.
i havent at all progressed in this..Smiley Sad so i have not got anything to attach.
Please help me.
Message 1 of 9
(4,113 Views)
Message 2 of 9
(4,097 Views)
Define inner and outer corner. Can you attach a typical frame picture?
Do you need help finding the center and corners (maybe hard) or do you already have the pixels coordinates (trivial).
Message 3 of 9
(4,084 Views)
i need to find out that as well... and i havent yet progressed at all...
Can u help me regarding that too sir,..?
Message 4 of 9
(4,079 Views)
It seems like even defining the problem is more effort than you feel like putting in. This is why you don't progress.
Message 5 of 9
(4,073 Views)
I am really new to labview.. thats the reason why i cant figure out what to do..
Message 6 of 9
(4,069 Views)
Well 'i'm really new' is often a codeword around here for someone that hasn't even sat down to learn the basics of LabVIEW. You need to read the manual and go through some tutorials/exercises if you haven't already. Depending on your license, you may have free access to the LabVIEW core training programs.
Message 7 of 9
(4,059 Views)
So, the main problem is the image analysis. You have not shown us a tyical picture as requested.
is it color? black&white? What is the resolution? What is the frame rate you need?
So many questions, so little information!
Message 8 of 9
(4,048 Views)
mm.. am sorry sir,
 The image is color..il attach one..
frame rate is 30fps..
Message 9 of 9
(4,024 Views)
