mechanical action property
Hello Labviewers
Does anyone know if this is possible:-
Two buttons, one button changes the mechanical action of the other button.
i.e button 1 is false then button 2 acts as a switch, button 1 is true the button 2 act as latch.
I want this in order to have one button that saves data in different ways, i.e button 1 could be 'save by pt' or 'save all' and button 2 is 'store'.
If I could use a property node for mechanical action it would be easy, but I can't find that. Smiley Sad
Any ideas anyone?
thanks in advance
Ieon
(3,534 Views)
Hi Leon,
here are two options:
1) button 2 is a switch, after saving a point copy button 1 value to button 2 via a local
2) create two button 2 exactly overlapped, say button 2a (switch) and button 2b (latch); depending on button 1 show one of them and hide the other; save on 2a OR 2b
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,524 Views)
You could have both buttons as switch action. Now, if you want to use latch action, activate a case where the value is reset via e.g. a local variable.
See attached simple demo, LabVIEW 7.1.
Message Edited by altenbach on 11-11-2005 10:19 AM
(3,513 Views)
Of course if you have LabVIEW 8.0, you could make an Xcontrol that does everything. 😄
(3,509 Views)
Hi There
Thanks guys for your ingenious suggestions Smiley Happy, much appreciated.
I'll have a dabble to see which works best.
Thanks again
Ieon
(3,483 Views)
