media
Hello
I have a signal variable in time, that is the real wind speed, ... so I want to obtain the average value of this signal every 10 min.
Can you help me?
Message 1 of 13
(4,703 Views)
Hi enzo78,
can you show your code? If you use a loop, then add a shift register to it and store your value in it. With the "Add Array Elements" function and a simple divide block, you can than calculate your average.
Mike
Message 2 of 13
(4,694 Views)
Here is my vi
thanks
Message 3 of 13
(4,687 Views)
Hi enzo78,
see the attached example.
Mike
Message 4 of 13
(4,675 Views)
Thank you
It`s good.
Bye
Message 5 of 13
(4,669 Views)
Hi
can you give me a manual to better understand the use of shift register and the loop
Cheers
Message 6 of 13
(4,661 Views)
Here is a version of MikeS81's VI with an alternate calculation which does not grow the array indefinitely. It does not store all the values, only the sum and the count.
It also shows how this can be done without local variables.
Lynn
Message 7 of 13
(4,658 Views)
Hi enzo,
there informations in your online help. Smiley Happy For more informations see this link http://www.ni.com/academic/lv_training/d/how_learn_lv.htm
Mike
Message 8 of 13
(4,626 Views)
Hello
I`ve another question for you about the same VI,
The average value obtained is variable in time untill I stop the while loop, so I`ve stopped it with an elapsed time, wich stop it every 600 second.
Now I need to take only this value and to put it into a grafh: wind speed in y axis and present time (text) in x axis.
Somebody can help me?
thanks
Message 9 of 13
(4,603 Views)
I send my new VI
Message 10 of 13
(4,602 Views)
