mediaplayer problem
hello guys,
i wrote a  simple programm, that empedded the media player. i give the order about the invoke node to the mediaplayer. my problem is, that the invoke node reward has no effect about the avi file. why??
the invoke node stopp, play, break for example works fine...
i wrote in lv 7.0
greeting christian
Message Edited by wolf0815 on 07-25-2005 04:13 PM
(3,727 Views)
Hi Christian.
For some extrange reason, ff and fr invoke node do nothing in media player.
There is an easy a practical workaround: read current position property, add 1 or more and write back current position. In this way, you can control the speed of fforward. Same using minus 1 for fast reverse.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,712 Views)
hello alipio,
have you an example, and thank you for your quick answer...
(3,693 Views)
Hi again
 You can download an example from this web:
The name is player1.
Hope it helps
Alipio
(3,690 Views)
hello aliplo,
thanks a lot, that is exact the right stuff, thanksSmiley Very Happy
(3,679 Views)
