memory cannot be read
When I run my application, after a few minutes I get the following error message I attach here. And then LV exit and quit my application.
I use LV7 with MySQL and Win 2000.
And it says to me: Memory cannot be read
What happens?
ToNi.
(3,062 Views)
I've seem this error from time to time, and not just in LabVIEW.
I believe it's a generic error that Windows generates when it's having problems reading memory locations, though I've never found a good explaination of it. A lot of references point to a bad memory module.
Is it something that happens consistantly? Can you reproduce the error following a certain sequence of steps?
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,048 Views)
hi there
when a memory-error occurs after a certain amount of time i would search for memory holes, especially when you are working with ActiveX because of the usage of references. observe the memory - usage of your app in the taskmanager and be sure to close all references not needed anymore.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,038 Views)
