memory.cpp line 342
I realize that this is a common problem, I found lots of others with similar questions. My problem is that I only get this error on one perticular file.
Everytime I try to do anything with this file, open it or even look at its properties, I get the error and labview closes.
I have tried opening this file on another computer with a fresh install of labview 8.2 (using 8.2 everywhere) - nope.
I have tried opening this file in another hard-drive location. I ignored all the control definitions it tries to load. - nope.
I can submit the entire project if that may help, but really i think its the file.
This file is just my front panel to the user. There is nothing in it but a while loop set to a stop button and a bunch of references. I do however have a TON of controls on this page. Dont think that should do it though. The second computer I ran this on has 2GIG of RAM.
While working on the file, I had Labview crash out on me every half hour. I tried to recover this file after the latest crash and immediatly got this error. It could be that the file is corrupted?
Any assistance would be much apprecieated.
I am running Labview 8.2 on XP sp2.
(3,155 Views)
I could open it in LV8.5.  I tried to save it back as 8.2 attached.  Had to ignore many errors from the missing .ctl's
(3,146 Views)
Many thanks RAMaston. That did the trick. Saved me two days.
Kevan -
(3,133 Views)
