memory is full error on notifier
hi
i made a notifier as the picture attached. after few seconds i have this error :
(HEX 0x2) Memory is full.
what should i do to prevent this error?
Thank you
Message 1 of 23
(4,378 Views)
What is happening in the rest of your VI?  Was this code inside of a loop?  The immediate issue I see is you are not closing the notification.  So if this is done in a loop, you just keep making more and more references to the notifier and you will eventually run out of reference numbers (I don't remember what the number is at the moment).
Message 2 of 23
(4,367 Views)
i send data Continuously to another vi.
how do i close the notification?
Message 3 of 23
(4,363 Views)
@ehsan75 wrote:
hi
Thank you
Don't fill the memory ... 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 23
(4,355 Views)
To close the notifier you just use Release Notifier. However, why don't you open the reference before entering the loop and just use the single reference until you end. Then, upon exit, close the notifier reference.
Message 5 of 23
(4,348 Views)
this two pictures is what i did.
is it correct?
can you show me an example?
thank you a lot
Message 6 of 23
(4,327 Views)
You still don't show us enough code to see where your loops are.
Here is the basic example.
Message 7 of 23
(4,321 Views)
this is where my loop is my whole codes are in the loop. you saying i should create a loop for notifier as your example?
Message 8 of 23
(4,316 Views)
Are you saying that you're using a notifier to send a notification within the same loop? If that's the case then use a wire. RavensFan's example was to show you how to do the notifiers that we assumed to be in different loops.
Message 9 of 23
(4,306 Views)
Typically notifiers are used between loops because there are other simpler mechanisms to communicate within the same loop.
Since you hadn't shown us anything but the tiniest pieces of code, I had no idea what you are doing.
You asked us to give you an example on how to use notifiers, so I did.
Message 10 of 23
(4,302 Views)
