memory management
Good morning,
I'm trying to optimize the memory management of a program for statistical analysis of 2 and 3 dimensions arrays that uses different front panels, accessible through a main front panel. The program works with files with size of 300 MB and after few operations the program reaches the memory limit and crashes. I improved the situation by using the "request deallocation" but I still can not use some parts of my program. The program has been set ( I didn't written it, but I have to improve it) with a massive use of local and global variable that generates,  as far as I know (using "tool>profile>allocation arrays"), a memory allocation every time there is a local/global variable in order to create the copy of the data. How can I improve memory management? Is rewrite the program the only solution?
greetings
Paolo
(2,814 Views)
Hi Paolo,
you can improve your program (in terms of memory usage) by removing globals and locals. So you need to rewrite (atleast parts of it)!
There is a KnowledgeBase article on handling large datasets, search for it!
(2,809 Views)
