menu bar shows when I stop the error 8 occur during run mode of .exe file
when error 8 occured and I click on "stop" option rather that "continue".then vi stop and file,edit menu shows. in exe RUN mode,this is also  happend so what is the solution for not seeing the menu bar when i stop the error 8 option in run time. it should be stop as it is condition..
Message 1 of 9
(3,426 Views)
You can use "quit labVIEW" vi.But i would not recommend this.You obviuosly need to display the run button right?
Message 2 of 9
(3,411 Views)
You can put your exe in the startup.Did u do this?
Message 3 of 9
(3,409 Views)
Hi Milap,
please avoid double posts! You can edit your posts, no need to start a completely new threads for the same topic...
Message Edited by GerdW on 06-26-2008 10:11 AM
Message 4 of 9
(3,404 Views)
ya sorry for that....
but the problem is always there.....yes I can use quit option rather then stop.....but when popup dialog box of error 8 occur then we have no any command to quit...there are only 2 option whether you Continue or you can Stop.....so when you continue then error ocuur and occur continue.but when you click on Stop then only .exe stop.not quit....you have no command on error dialog box.....
Message 5 of 9
(3,397 Views)
so is there any option to stop popping up the error 8 dialog box....
Message 6 of 9
(3,396 Views)
Hi Milap,
have you read my comment in your other thread?
This error message pops up when you don't have programmed any error handling!
Well, you use "Write to spreadsheet file" for saving your data. Look inside this function (and it's subvi "Write Spreadsheet string") to see how to use low level file functions. After the "Open/Create/Replace File" you have to check for any error (like error 8)...
Message Edited by GerdW on 06-26-2008 10:44 AM
Message 7 of 9
(3,389 Views)
Hi Milap,
If you think that there has no relevance, there is a way to ignore particular errors in LabVIEW. The below knowledgebase lists the steps.
Ignoring a Particular Error in an Error Cluster in LabVIEW
Hope this helps!
Warm regards,
Karunya R
Message 8 of 9
(3,366 Views)
     If stopping popup is what u want.U can connect the error to simple error handler and select no popup.I use this to combat time out problems sometimes.
Message 9 of 9
(3,353 Views)
