menu ring with variable values and labels
I have a question about using a menu ring with variable “values” and variable “labels”. When I load a “value” combined with a “label” into the menu ring, the first thing I see, in the menu ring, is the “value” number instead of the label. Is it possible to see the first “label” instead of the first “value”.
I attached a simple example of my problem, when you run this example the “value” is visible instead of the label.
Message Edited by Bart L on 03-17-2006 06:09 AM
(3,170 Views)
Hi Bart,
Look at modified version of your VI.
Use shown properties
Regards
Dev
(3,153 Views)
Hi Bart,
I changed it a little bit and it "half-works"...
I let you see what I mean by half-works... I couldn't find an explanation Smiley Indifferent
Hey.... well done Dave, you were faster and more efficient !
Message Edité par TiTou le 03-17-2006 01:26 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,154 Views)
TiTou,
Merci beaucoup!
Smiley Happy
Regards
Dev
(3,127 Views)
