merging outputs of two loops and writing it into a text file
      i am currently working on a labview. anybody help me how to merg a output data from two independant loops in labview and writing them into a text (lvm) file. one loop output is voltage and other output is current, how to merg these outputs and how to write them in a text file?? help me please..
                      thank you!!
(2,783 Views)
Convert both into string array.Use build array to combine the data.
then use "Array to spreadsheet string" function and file IO functions to write it into text file.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,777 Views)
I attach what I undestood you required. Hope it helps.
Greetings
Andres
(2,774 Views)
