mermery of graphic
hello,I find my graphic who has a problem, it shows diffrent graphic with the same file WAV.
i think is the problem of memery.
anyone can take a look?
thanks
帖子被xiuming在 06-12-2009 08:18 AM
时编辑过了
帖子被xiuming在 06-12-2009 08:19 AM
时编辑过了
(3,322 Views)
Can you descript it with more details?
Do you mean you open the same wav file for twice, but the graph control shows different?
Regards
(3,288 Views)
yes, thanks for your reply, here is the problem labview7:
1. mermery of grahic:  final2.vi
 when i play the same file wav with the choix of differents filters, the sound output is ok, the graphic chang also, but when i choose the same filter, the graphics are differents.
2. continuous graphic: essayer.vi
in fact, i want to show the wav file, continuous like in recording. so i put the graphic in the while, but it show the last data, just the time is continuous, the chart  stays. maybe the data in the file is like a table, so it show in the same time, so shoud i need use some fonctions to make that?
thanks
(3,283 Views)
In your attached essayer.vi, I found that, in the play button value change event case, you place the part below in:
In my opinion, what you want to do is to diaplay the  wav file data continously, am I right?
But if the output of Time Elapse.vi is Flase, the indicator called Affichage 2 will receives the same data, each time the while loop runs, it displays the same data as if "the chart  stays".
I think you should change your VI to make it more readable.
帖子被willing_wy在 06-17-2009 03:56 AM
时编辑过了
Regards
(3,259 Views)
yes i want to display the file continously.
for the Time Elapse.vi, i want the Affichage 2  show every 20 secons.
  i think my VI need great change also, do you have some examples?
 thanks
(3,245 Views)
