mesh change color programmal
Hi, everyone,
I have a question about the color of mesh. I create mesh obtained from stl file and attach to a object. I have set a color to it, such as grey. And then I want to reset the color to green programmally. But I can not find the proper method to do it. So, I try to reset the mesh parameter and call set drawble method to do it. But there is an error when I run it. It seems that I can not call set drawable method twice for the same object? On the other hand, although there is an error but the color of object indeeds became the new color I want to set. Is there any suggestion? Thanks.
Hechang
(2,843 Views)
Really urgent, thanks!
Hechang
(2,814 Views)
Howdy,
The LabVIEW help article on Mesh parameters may prove to be helpful, you can find this here:
http://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/scenemesh_set_mesh_parmeters/
Also, the example within the LabVIEW example finder named: Using Meshes.vi may prove to give you better insight as to how to manipulate mesh properties.
Daniel G.
Semiconductor & Wireless
(2,785 Views)
