mesurer à partir d'un changement de tension
Bonjour,
Je suis e train de créer un programme de mesure de tension sous Labview 2011 avec un module Ni9219.
Je voudrais pouvoir mesurer ma tension en continue et enregistrer toutes modifications de tension de 0.01v avec le temps au bout duquel la tension a chutée.
Je ne peux piloter mes mesures que avec une fréquence de temps. Je n'arrive pas à passer d'une fréquence de temps a une fréquence de tension.
Merci de votre réponse
Cordialement
Message 1 of 16
(3,513 Views)
Hello axa-stenman,
Just to make sure i'm understanding you right:
You want to measure your voltage levels continuously and only log when the voltage changes with 0.01 V (or more).
Are you measuring voltage drops of ad DC voltage?
In which chassis are you using the NI 9219? How fast do you need to sample? What is your analog input range?
Which VI's are you currently using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 16
(3,490 Views)
Yes, I want to measure your voltage levels continuously and only log when the voltage changes with 0.01 V (or more).
I measure the voltage drop of a DC voltage in a Ni cDAQ-9171 and Ni cDAQ-9174.
I want to do 1 sample with a frequence of 10Hz. And the input range is between -10V to 10V DC.
Now i using a VI's with DAQ-mx task with a Express exit write measure in Labview 2011.
But i have seen another way. Is to using a E/S node in Labview FPGA but i don't know how to use this system and where it is.
Kind regards.
Message 3 of 16
(3,487 Views)
Hello Axa-stenman,
Using FPGA I/O nodes requires and FPGA.
In the cRIO platform you have an FPGA, but not in the cDAQ-platform.
Is the voltage drop compared to the first value you ever read or to a theoretically set one?
Or is compared to the value you have read 0.1s before.
Do you already have some code available?
Then I can adapt this to behave the way you want it to.
Kind Regards,
Message 4 of 16
(3,482 Views)
I want compared to the value i have read 0.1s before.
I have no already available code, just this code to modify or somthing like that.
Message 5 of 16
(3,474 Views)
I have tried to keep the code as closely as possible to the original.
Is this what you had in mind?
Kind Regards,
Message 6 of 16
(3,465 Views)
I have a problem with the Vi's. I can't download the file. I have a message "Le fichier ne peux pas être téléchargé. Le site n'a pas pu être trouvé ou n'es pas bon. Veuillez réessayer ultérieurement"
Perhaps can you send me the file in a mail.
Message 7 of 16
(3,437 Views)
Here's another try.
There were soms issues with the server, so here's a second try.
Kind Regards,
Message 8 of 16
(3,426 Views)
Kind Regards,
Message 9 of 16
(3,426 Views)
My problem is solved.
Best regards.
Message 10 of 16
(3,418 Views)
