metallic theme waveform graph
I am using the Metallic Theme to design a Labview Front panel.  I would like to plot some x, y data on a graph, however, there is only a Waveform Graph and Waveform Chart available in the Metallic Theme.  Can you assist me in plotting the x,y data to the waveform graph in the attached VI?
hiNi.
(4,277 Views)
Accepted by topic author hiNI
You can customize the Metalic Waveform graph and replace it with an XY graph and set some of the properties to match the Waveform Graph
Or let me do it for you
Attached back-saved for 2011
Cross Posted to the "Military Theme UI Discussion" on the Community Side
(4,233 Views)
VERY ELEGANT SOLUTION!!!
THANK YOU!
(4,221 Views)
