meter with image
Hellow, I'm doing the instrumentation of an apparatus for the final draft of the ISEC degree and was wondering if I could explain how one replaces graph meter for images, in my case wanted the -90 to 0 and an image appeared of 0 to 90 appeared another image, keeping on top of the bar numerical images of -90 to 90.
(2,551 Views)
Are you wanting to show the images rotating? If so, you can replace the image of the needle with the image you want to rotate.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,505 Views)
