method " make current values default "
hello
I use method of "make defult" and it works well but I must build application this vi
when I do this (tools ->build application ...-> installer setting) and  run
show  this error :
Error 7 occurred at Open VI Reference in mainpage.vi
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file
 path might be incorrectly formatted for the operating system. For example, use
 \ as path separators on Windows, : on Mac OS, and / on UNIX.
I add configure.vi  as dynamic file and when I press configuration buttom and
 then press ok buttom show this error:
Error 1044 occurred at Invoke Node in make defult.vi->mainpage.vi
Possible reason(s):
LabVIEW:  VI is locked.
please guide me how I can use this method and also make installer file
Thanks alot
Faeze Zar
(3,666 Views)
another question how could I attach my file?
(3,662 Views)
If you search on this forum "make current value default" you will find at least 10 threads dealing with exactly the same issue. This method does not work in an exe, there is a paper about his in the NI knowledge base.
The solution is to use a configuration file (ini).
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,659 Views)
I don't think you will need to upload your VI for this issue, but have a look at the bottom, the "attachment" section lets you select the files you want to upload.
Message Edited by TiTou on 12-18-2007 08:51 AM
Epictetus
Antoine Chalons
(3,654 Views)
I offered a number of solutions to this challenge in this Nugget. Take a look at that article and the included links. You should be able to find an approach that can help.
Ben
(3,613 Views)
Thanks alot for your answers, I changed my program and use ini file but
 I dont know how write the path of ini file in the main program that when it became exe and run
find ini file
 please help
(3,584 Views)
faeze wrote:
 I dont know how write the path of ini file in the main program that when it became exe and run find ini file
http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
(3,579 Views)
