micro robot path planning using NI Vision
Hello
I need a support to start a project on moving MicroRobot Position detection, tracking and may be path planning in later stage. I have gone through VIs available in Vision toolkit, example finder and also few tutorials online.
Could't find how to acquire real time Video stream in Vision, also when I tried for simple png file it gives me error that " file has to be 8 bit monochrome and mice is 32" How do I convert this....Honestly newbie ...need some hlep guys
Thanks !!!!
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(2,598 Views)
Hi vitualworld,
What vision softwware are you considering?  There are several options, but it sounds like the Vision Development Module is what you will want if you are doing some image acquisition and processing.
When you say video stream do you mean grabbing images from a camera?
This link may help:   Developer Zone Example: Grab and Save to AVI
As for converting your image, the IMAQ Cast VI should do the trick.
NI Vision Help: IMAQ Cast Image VI
As a side note, the best place to post this question would be on the Machine Vision Boards to get more views and a quicker response.
Hope this helps
Justin D.
(2,583 Views)
