microcontroller
hello everyone..
I have one question to u all. I'm using an easy kit XC866 8-Bit Single Chip Microcontroller from Infineon with serial interface.First of all...I have created a simple program and download it into this microcontroller. And all data values from the program can appear in Hyper Terminal or ASCII. Now, I want to convert this program into labview with helped by Instrument I/O Assistant. When I double click the icon  and click Read and Paste function there, The blue screen appears from my monitor and error, when I restart again, something like that happen again. So, is this XC866 compatible with labview since this is first time i use it with labview...thank u very much...Smiley Happy
(2,711 Views)
I don't know the XC866 , but since your microcontroller uses serial interface, you can communicate through VISA functions.
There are demo vis,  in Labview examples.
Just make sure you close the hyper terminal first....
(2,703 Views)
