micropulse generation
I want to Simulate a pulse train of maximum 300 pulses per sec in Labview having following specifications:
On time: 10 us
Rise time: 500 ns
Fall time: 500 ns
Peak Pulse Amplitude: 3 V.
I tried simulating the signal using Express VI as well as other Signal processing palette but couldn't generate the exact signal. Is it possible to generate a waveform having above mentioned parameters in LabVIEW?
Any help is appreciated.
Message 1 of 10
(5,475 Views)
Yes, that's possible: Use a dt of 500ns…
Message 2 of 10
(5,473 Views)
Can you be a little more elaborate, please?
I didn't see any 'dt' option in Express VIs.
Message 3 of 10
(5,417 Views)
Hi arihant,
"dt" is a parameter of a waveform…
And I would avoid ExpressVIs, there are a lot of nice functions in the signal generation palette!
Message 4 of 10
(5,408 Views)
Thanks for the reply.
I will to generate the pulse train without using Express VI and will message you if face any problem.
Arihant
Message 5 of 10
(5,368 Views)
Hi GerdW,
I tried generating a pulse train using palettes available in Labview. The vi exucutes but shows zero amplitude only but not a pulse train. I am attaching the vi herewith. I am unable to trace the mistake. If possible kindly point out the mistake I am making.
Arihant
Message 6 of 10
(5,315 Views)
Hi ari,
why so complicated?
Message 7 of 10
(5,303 Views)
Hello GerdW,
Thanks for your effort but I couldn't open the file due to version issue.  I am using LabVIEW 2011 SP1. If possible, kindly attach a compatible vi.
Sorry to bother you so much regarding this.
Arihant
Message 8 of 10
(5,283 Views)
Hi Arihant,
the VI looks like this:
Message 9 of 10
(5,268 Views)
Spoiler
Smiley Surprised
I was taking help from labview examples. Silly me.
Thanks a ton.
Learning to play with the palette parameters. They are also giving me a nightmare.Smiley Very Happy
Will get back to you very soon.
Arihant
Message 10 of 10
(5,215 Views)
