migrated from VBAI to labview 8.2.
I’m fairly new at these vision programs and need some advise.  I have migrated from VBAI to LabView 8.2.  However I can’t seem to get the LV program to work like VBAI program works.  The LV program gets stuck in a loop processing the same photo rather than the entire folder of 25.  The other problems are: It will not show the photo; it will fail all photos, and will not log results.
I am running the LV 8.2, Vision Acquisition 8.2, and VBAI 3.0
(3,287 Views)
Hi Davis,
it's much easier to give some advise when you would attach your vi 😉
(3,278 Views)
This vi was generated by the migration process.
(3,266 Views)
Hi Davis,
now I only not those dozen of sub-vi's.
Please use 'save as' and 'Duplicate hierarchy' to get all sub-vi's. Zipping them into one archive to allow easy attaching in the forum.
(3,261 Views)
(3,235 Views)
Hi Davis,
I'm not experienced in VBAI and IMAQ, but in your code I couldn't find any function to load your JPG photos...
There's only an 'IMAQ Create' in the initialize-sequence, which generates an empty image. So it seems you have to attach your own code here 😉
(3,230 Views)
