min max
Hi all : Does any one have build vi that shows  min and max in graph  thanks
(4,991 Views)
All you need is to get the array of values and then use the Array Max& Min function. How do you get the array of values? Depends on what kind of graph you have, and whether you have one or multiple traces.
(4,983 Views)
Hi Elyan,
Please find attached a demo vi that should help you along, change the simulated signal express vi for your application. I am assuming that you are running LabVIEW 8.5 if you are not I can convert the vi for you.
Best Regards
Ben L
Field Engineer
(4,973 Views)
Your question has two parts:
  1. Find min&max
    • Do you wan the min&max for each trace,
    • ...or the min&max for each x value (in the case of multiple traces)
    • ...or something else?
  2.  "show" the min&max.
    • Place a cursor
    • Use annotations
    • use two additional plots
So far your question is too vague for a precise answer. Can you attach a simple VI or an image that shows what you actually need? Thanks! 🙂
(4,961 Views)
Hi :
i want to bulid vi that show and do this , please attach see file
thanks
wisam
(4,921 Views)
Do you mean that you want a vi that shows lines on a graph located on the Front Panel of the VI?
or
Do you mean you want a vi that creates the max min lines within an Excel application?
"I want this & that" is not very specific, especially if you show an example of a non-LabVIEW application.
If you do want a Graph on a LabVIEW Front Panel, then have a look at the attached example.  It is done in LV7.1 to illustrate how you could do it.
R
(4,890 Views)
