minimize Window programmatically
When I start my application, I would like to have its (main-)panel
minimized and after some guided initializations I would like to maximize
it.
I tried to do this with VIserver functions, but without sucess. Can I
change VI properities from inside this VI? Can I change it only in exe?
or without allowing debug?? Thanks for education!
Maybe soembody of yours has abetter idea how to handle this !
Urs
Message 1 of 12
(8,365 Views)
try to look in lvwutil.zip. These are window controlling utils.
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/162d5ec0e0fd94778625667a005f2de4/
Hope it helps.
Oleg Chukto.
Message 2 of 12
(8,365 Views)
Th 32-bit version is at
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/ebf11dd1f0feaef3862566790072a983/
Oleg Chutko
Message 3 of 12
(8,365 Views)
If you are using Windows there is a set of tools for LabVIEW called LVWUtil32 that contains a Minimize Window.vi and Restore Window.vi that should do what you want. You should be able to get it (LVWUtil32.zip)at the bottom of this knowledge base: http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/824b3db43031317686256aaf00713218?OpenDocument .
Another idea would be to display some sort of splash screen that covers your main vi while the initialization is going on and then closes when its done.
Brian
Message 4 of 12
(8,365 Views)
Thanks very much for the answers so far - I will give it a try tomorrow.
I'm still wandering about my questions.Can I
> change I VI properities from inside this (same) VI itself?
> Can I change it only in the exe mode or in in developement ?
Best Regards
Urs
Message 5 of 12
(8,365 Views)
Yes you can set it to minimize from inside of itself. See the example I attached.
It works in both exe and development.
Not sure what you mean.
Brian
Message 6 of 12
(8,365 Views)
Hi Brian,
starting your example, LabVIEW reports missing the VIs Minimize windows and restore windows.
Can you post the here, please?
Thx,
Rainer
> I attached.
> Brian
> MinimizeExample.vi Type: LabVIEW Instrument (application/x-unknown-content-type-LabVIEWInstrument)
> Encoding: base64
> Description: Exam
ple
Message 7 of 12
(8,365 Views)
They are part of the LVWUtil32 library that was linked to in the other answers to this question. It can be found here: http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/ebf11dd1f0feaef3862566790072a983/
Good luck.
Brian
Message 8 of 12
(8,365 Views)
Thx Brian,
Rainer
Message 9 of 12
(8,365 Views)
Is there a way to get these VI's working on a Windows 64 bit system?
Please as much detail as you can provide.
Message 10 of 12
(7,047 Views)
