minimize sub vi
Looking for a solution, need to minimize a sub VI but continue to let it run while navigating through other VIs.  I have a GUI project, the front panel can call up a small window that displays alarms.  Everytime I open this window it has to update, I would like to minimize it and still be able to navigate to other VIs in the project.  Last it would be a benefit to be able to bring it back up if called through one of the other VIs that is running in the foreground.
(2,689 Views)
Hello Slud,
I think that the following link can help you with your question:
http://forums.ni.com/ni/board/message?board.id=170&message.id=216965&requireLogin=False
If this not enough, post again and tomorrow I'll help you.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,676 Views)
