minimum daqmx driver install
I have an appliction which uses daqmx ai and a few dio with a ni-usb multifunction device which is going to be distributed widely (eventually).  What is the minimum install footprint I can provide.  I am concerned about the size/time it will take to install the 3-disks that come with the devices.  Does anyone know the minimum install and how to set this up from LV8.5 installer.  Ideally I dont even have MAX on the client computers, just an istall that contains the minimum.  I will use the daqmx system to scan for devices and find the correct usb device so naming convention is not even required.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,510 Views)
Paul,
For data acquisition applications, the best practice to achieve the smallest footprint possible is to create a LabVIEW executable and use DAQmx Base driver.  There is no way around it, you will a DAQ driver of some kind so the hardware can interface with your computer. and DAQmx Base has a significantly smaller footprint than full DAQmx.
-Marshall R
(3,480 Views)
