minute to hour convert
hi,
      how to convert 150(int)minute to 02:30(string) hour minute.if any other method without this program.
Message 1 of 12
(4,158 Views)
I prefer Scan from String (as I can do it "all at once"), but it is basically the equivalent of your code.  That's about as efficient as it comes ...
BS
Message 2 of 12
(4,149 Views)
Accepted by topic author GokulGKM
I think you mean Format String in this case.
Message 3 of 12
(4,141 Views)
Use Format Into String with %.0t as format string.
Ben64
Message 4 of 12
(4,119 Views)
... and don't forget to multiply the minutes by 60 as seconds is the base unit for time conversions.
Ben64
Message 5 of 12
(4,090 Views)
Oops ...  Of course I did.
BS
Message 6 of 12
(4,069 Views)
hi,
      pls send me some example...
Message 7 of 12
(4,041 Views)
madhanskm wrote:  pls send me some example...
Message 8 of 12
(4,005 Views)
@madhanskm wrote:
hi,
Ben64
Message 9 of 12
(3,988 Views)
I'm currently trying to do some verry similar...
Input: # of minutes to countdown
Output: countdown time string in HH:MM:SS format. (I realized the correct format is %02d right after I uploaded it)
pic of code (vi is attached V2014):
http://i.imgur.com/ssHGMI5.png
Is there a smarter way to do this where is skips the "00:01:60" count?
-pat
Message 10 of 12
(3,877 Views)
