mismig file for ppcbattery example
I entered this link http://zone.ni.com/devzone/cda/epd/p/id/1476. In the block diagran of "PPC battery Info.vi" it says that you need to build the file with a file name "PPCBatt.c". this file is not exist in the folder at this link. Does any one have it?
(2,835 Views)
Eran:
I looked through all the folders and could not find the "PPCBatt.c" file either. There is however a c++ file in there with the same name, you can try to change the extension to ".c",use it and let me know what you get.
Rudi N.
(2,823 Views)
Rudi N , Shalom,
Thank you for your reply. The "*.cpp" file is good for this application,
They should change the instructions in the vi for other users comfort.
Thanks again,
Eran
(2,812 Views)
Eran:
I am pleased to know that things are working fine. I will make sure that the instructions are changed to reflect that.
Rudi N.
(2,801 Views)
