missig library vis daqmxwrite
hello.
Having a new problem.
Im trying to open up what was a working project, Im getting promped for daqmx write(analog dbl1chan1samp).vi
I have tried installing labview, the daqmx base (NIDAQmxBase330), and the labview 2009 driver DVD 1
No luck
Rebooted each time.
I had this working, i was trying to remove a lot of installed items i wasnt using before going to production with this.
I must have removed something that i shouldnt have, because even labview 2009 got uninstalled although i dont specifially remember doing it.
was remvoing the PXI stuff and a few excel plug ins.
anyway, any help is appreciated.
(2,846 Views)
Were you using DAQmx Base or DAQmx? You may need to install DAQmx in order for your project to work.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
Andy Chang
(2,839 Views)
thanks, yup, thats it.
(2,820 Views)
