missing browser plug's
When I publish front panel using viewing mode as embedded the front  panel doesn't display and plugin not supporting with Chorme and missing plugins with Fire fox. Yet I have installed Labview Run-time Engine 2012 with all plugins and still embedded view mode dosenot working. Please give some suggestions.
(3,491 Views)
  1. Is the LabVIEW version also LabVIEW 2012?
  2. Did you follow the instructions here? (some information seems to be stale, see below)
  3. Yes, chrome no longer supports NPAPI as of September 2015 (details)
  4. Is your netscape 32bit or 64 bit? (64 bit netscape is not supported and 32 bit NPAPI support will also be dropped late 2016) (details)
  5. Have you tried internet explorer?
(3,478 Views)
Im using Labview 2012
I did refer this page https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M9WSAU&l=en-US
I did try using internet explorer 6.0
I think web server is working, because I was able to access html with embeded viewing mode using  internet explorer 8.0  with a differant client and i used internet explorer 10 with another client and it also not working all clients have labview 2012 and labview runtime engine 2012.
(3,458 Views)
