missing daq assistant on my express vi palette
I installed Labview 2012 on my windows 8 OS and discovered the DAQ Assistant VI was missing. How do I get it on the palette?
(3,716 Views)
Make sure you have the DAQmx driver installed as well. Also make sure to check the readme of the driver to check that the driver is supported with the version of LabVIEW you are using.
(3,701 Views)
Accepted by topic author stasism
For additional reference: NI-DAQmx and LabVIEW Compatibility
(3,673 Views)
i removed NI Daq 15 and installed NI DAQ 9,5 and that corrected the situation
(3,654 Views)
