missing file extention 3dsurface.vi
i am working with a graphing vi and it wants to call a sub vi (at least thats what i think) callled 3dsurface.vi   i found a link for it on this site using google but the link was dead i was hoping someone could fix that for me.  Thanks for any help
(3,284 Views)
3D Surface.vi is part of the 3D graph library that comes with LabVIEW. Which LabVIEW version and edition (i.e., student, professional, etc) do you have?
(3,262 Views)
I am not sure then i will double check with the computer tech.   Thanks for the help.  They just installed labview yesterday and they dont know much about it.  When i found that 3dsurface.vi was missing i asked them about it and they spend 30 mins going through all the labview stuff they had.  Maybe this time i will get the stuff from them and double check.  Thanks for the help gave me a good direction.
(3,256 Views)
If you have the base package, you will not have access to this feature.
If you have anything other than base package and you are working on Windows OS, then you should look for the file under the National Instruments directory \LabVIEW X.X\vi.lib\Platform\3dgraph.llb
Hope this helps!
AG
(3,241 Views)
